C2s cab 06' water drop from the top and the window driver side.
8th Gear
Hi
My 06 cab has some water get inside during heavy rain.
I saw water drop from the rubber seal. Window and the top
Is it normal for cab model?
no. seals should be tight all around. Doors should close tightly onto cab frame as if it were a coupe.
If the cab top has been repaired/replaced for some reason is suspect to think something is not right.
Track down leak, could be originating from another location where water is coming thru; Seals should be closely inspected, lubricated. run some water from a garden hose across the front seal/windshield frame to see if that area is sealed properly.
Spray water onto the side window areas to check for leaks on all side windows/seals.
good luck.
good luck.
8th Gear
Yes, you are right. It leaks from the window seal, driver side. Are that the top is folding.
Should I replace the whole seal?
The top has been replaced before.
