the dreaded "take to workshop"
Official Rennlist Snake Slayer
I usually drive the Porsche (09 C2S Cab, PDK) to the office on Fridays, and this morning was no different.
Turn the key, and it cranks and cranks - no fire. Finally fires, runs rough as hell, kinda like the old days when the choke was stuck or timing was way off. Had to pedal it quite a bit just to stay running, and it still cut off. Turn the key off, remove it, start all over again, same thing happens, except this time it throws a "engine reduced power" alarm.
Try it one more time, get the "reduced power" alarm, followed by the dreaded "take to workshop" alarm.
Tow truck is on the way.....
Last time I drove it was last weekend - and it drove fine - in the garage ever since then. I've had the high pressure fuel pump recall done, and it's still under warranty, but this is disconcerting.
Any ideas as to what the problem may be?
Yes...fuel pump. BMW did the same thing. These high pressure fuel pumps will be an issue forever. Low viscosity and high pressure piston pumps make for a bad combination. They'll probably figure it out some day but for now direct injection engines only problem is the fuel pump.
Another clue....
tow truck has it, and it's on the way to the dealer. Driver was able to crank it and back it out into the street, running rough as hell.
there's a small puddle of what appears to be oil on the floor underneath where it was parked. It's never leaked, and uses very little oil. It's hard for me to tell how much oil is really there as I have a plastic tile (racedeck) underneath it. Crapolla....
Does the high pressure fuel pump have a lube system that failed and spewed?
Another clue....
