Remote control for Gundo or Fister exhaust possible?
I might do fabspeed if there's no other option, but I'd prefer the stock exhaust sound when the valve is closed. Thanks!
Also check out Carnwal - They produce a plug in remote system for the OEM PSE system.
http://www.carnewal.com/
See it in action here.
Also seems fairly cheap at 150 Euro's
I had thought of installing a manual 'T' bar handle valve to be able to reach under and open/close as needed. Not quite as clean of a process, but would probably serve the purpose you require.
I recently had the 'gundo' done to mine and even with a full 2" pipe, it is not overly loud. Initial start up is pretty loud, but then quiets after 30 seconds or so. Driving around, it is not really noticeable. Not sure my wife would have known a difference if she didn't know I was doing it...
