Suspension upgrades
RSS FRONT LOWER CONTROL ARM
STORMSKI RACING REAR TOE CONTROL ARM
TPC SWAY BAR KIT ADJUSTABLE, FRONT AND REAR
RENNLINE DROP LINK FRONT
RENNLINE DROP LINK REAR
They are quoting $3,500 for the parts and $1,400 for the labor; reasonable? They claim to need 14-15 hours for the mods. Any experiecne with parts from different brands?
Appreciate any thoughts.
Thanks,
Patrik
. You also might want to do the rear dogbones "while at it" (famous lat words).May I ask why you are going for a different vendor for each part in your setup? Wouldn't it be easier to stick to a single source?
I put all this stuff myself and it did not take me 14-15 hours, even though I had to lower the subframe for the sway bar and I do not have a lift... So it sounds a little high just from a parts install perspective but it is definitively not less than a very full day...
That being said, if it includes the alignment you will most certainly need after putting this stuff in, the number would make sense.
You could probably save $50 here and there but sometimes, going with someone you trust is more important...
HTH,
T.
