Clutch problem after oil change and brake flush
No sure if this is coincidental but the day after I got an oil change and brake flush the car keeps asking me to "depress clutch" when starting. It happens now almost everything I start the car. I was at a light today and had trouble getting from neutral to 1st. Any ideas??
If you have trouble getting into gear when the car is already running, I am sure it is not the switch but rather some air in the hydraulic clutch assembly. I believe the clutch and brake systems may share the reservoir.
of the cluch pickup feed (second line) in the reservoir I guess you *could* get some air in the clutch hydraulic line, and slave cylinder, depending on who's pumping pedals.
Question... So I took my car to a local "top" porsche mechanic in NJ. I just called him and explained the issue (me getting the car in gear has only happened once so lets say that was just driver error). When I asked him about bleeding the brakes causing the problem he said "impossible". Was he suppose to have bled the clutch slave cylinder after he did the brake flush??? It doesn't sound like he did if he is telling me the brake flush and clutch issues aren't related. He says it is the switch is most likley to blame. I am bringing the car to the dealer (it is under warranty) to have them check out the clutch but I am curious about the clutch bleeding...
After reading your original post again, I am thinking it could be two unrelated issues...
1. Your clutch switch is not quite right which could give you starting problems.
2. You are experiencing the common balky 1st gear synchro issue which is normal but this should not start happening only after the car is serviced. It could be air in the line.
thanks. yeah i think the gear thing was a fluke as i was rolling a bit. i know 1st gear can be funky. my only outstanding question is does the clutch need to be bleed when you are flushing the brakes?? i know for a fact he bled the brakes but NOT the clutch.
Yes it should be. It is all the same system. Otherwise they didn't get that old fuild out too.
Glad they found the problem. With these complicated cars, I’m a great believer in the principle of Occam's razor where you select from among competing hypotheses and that which makes the fewest assumptions usually offers the simplest explanation.
