wheel/tire qestion
wheel/tire qestion
On my 09 Targa 4 I'm currently using 19' turbo oem wheels. I believe they are 19 x 8 et 57 and 19 x 11 et 51. The tire size's are 235/35 19 & 295/30. I'm thinking about go with a new wheel that are 19x8.5 + 56 and 19x11 + 51. Any problema with the from being 8.5 with a et of 56? Thanks
The front is a close one, but seems like it might work. I'm sure some of the offset experts will chime in. Whatcha' gonna do with those 19" turbos when you take them off? I might be interested in them.
thanks do you think i can use my current tires?
Optional wheel on 997.1 is 8.5 x19 et 55 with 235/35 mounted so I don't think you'll have any problems - from the onwer's manual:
or front 235/35 ZR 19 (87Y) 8.5 J x 19 H2 55 mm 58.7 in./1492 mm
rear 305/30 ZR 19 (102Y) XL 11.5 J x 19 H2** 67 mm 61.0 in./1550 mm
