Horn sound ?
Old 05-08-2012, 08:00 PM
dak911
dak911's Avatar
Default Horn sound ?
I think there is something wrong with our horn...It kinda "peeps"
I remember a much better sound on the older aircooled cars...I think I remember air horns?
Whats up with that?
Old 05-08-2012, 08:06 PM
JMA
JMA's Avatar
I think there are two horns. One of them has probably gone bad leaving you with only one and an anemic sound. The bumper has to come off to repair. If you are not out of warranty bring it into dealer to fix. If you are out of warranty, then you have to decide. I'd probably blow it off if it was me. I had mine fixed ("R/R low horn") under warranty as part of my final punch list for Porsche just prior to expiration. Good luck.
Old 05-08-2012, 10:45 PM
Frontside720
Frontside720's Avatar
My horn sounds like the roadrunner only 15 octaves higher.
Sounds like what a SMART car should have.
You can buy a new one at suncoast with two different pitches but as long as it works, just deal with the sound.
Old 05-08-2012, 10:55 PM
Alan C.
Alan C.'s Avatar
Received 1,042 Likes on 535 Posts
There are two horns. If one goes bad the horn sounds a bit weak. It happend on my car.
Old 05-08-2012, 10:59 PM
sharmat
sharmat's Avatar
Weird but common failure on these cars. Funny, the horn on my 25 yr old BMW has never failed me.
Old 05-08-2012, 11:39 PM
docfink
docfink's Avatar
Yes, the 997 has horn issues. Mine was fixed under warranty. Contact your dealer.
Old 05-08-2012, 11:48 PM
91469972's Avatar
We have horns?
Old 05-09-2012, 12:33 AM
Waxer
Waxer's Avatar
Every 997 I've had had a horn go bad. It s not a 997 if you don't have a horn go bad.
Very common.
Old 05-09-2012, 02:10 AM
Zeus993
Zeus993's Avatar
Received 1,268 Likes on 585 Posts
Ah yes... But the true horn we need is this... a Stebel Nautilus
http://www.griotsgarage.com/product/...ortby=ourPicks
Check it out.
Old 05-09-2012, 07:45 AM
dak911
dak911's Avatar
Is there a space to fit the Griots horn on a 997? Anyone done this?
Old 05-09-2012, 09:48 AM
GSIRM3
GSIRM3's Avatar
I owned a 2007 997S, 2008 997S, and my current 2012 GTS. I had a horn fail on the 2007, and now on the 2012. I don't understand how Porsche could be using such crappy horns. I figured when one failed on my 2007 that they probably just got a bad batch of horns from a supplier, and the bad ones would eventually be eliminated. I can't believe that this is still an issue. I have never had a horn fail on any other car I have owned at any price.
Old 05-09-2012, 09:52 AM
Waxer
Waxer's Avatar
Old 05-09-2012, 10:47 AM
Zeus993
Zeus993's Avatar
Yes. It does fit. I am planning making the change. I believe SKIBUM has done it.
Old 05-09-2012, 01:51 PM
AP997S
AP997S's Avatar
There are (2) horns located behind the front bumper cover (passenger side). The cover must be removed to service them.
One is a 'treble' horn while the other is a 'bass' horn. My 'bass' horn failed months ago which results in a 'girly' high pitch beep. Almost embarrassed to use it in my 'manly' 997. I did replace it w/ an OEM horn and now I get the 'manly' toot or honk.
Would be a great bit on the old Tim Allen Show (ruff).
Old 05-09-2012, 04:10 PM
pissedpuppy
pissedpuppy's Avatar
Check it out.
yeah - I want something like this too, something really loud, like a frigging train. Griot's says this is loud, has anyone heard it?
Quick Reply: Horn sound ?
