Anyone try 3M Adhesive Remover on the Dash?
Previous owner had an after market satellite radio antenna mounted to the dash with some sort of adhesive. I've read 3M Adhesive Remover gets the job done. Before I try this I wanted to see if anyone else has tried this for removing adhesive from the (not leather) dash?
Here 's a link to the product: It says that it is safe on vinyl.
Jason
Jason
Here 's a link to the product: http://www.amazon.com/3M-03618-Adhes.../dp/B000BQYA7W It says that it is safe on vinyl.
Jason
Jason
use it sparingly. you may have to go over the whole dash to make the spot look less centralized and fade into the rest of the dash. after you use it put on some leather conditioner over the whole dash to blend the color back in
My dash is not leather - it's the standard vinyl (?) dash.
I was considering this too but I wasn't sure if it would be safe to use on the dashboard as it says do not use on rubber. The dash is not rubber but the surface feels rubberized. Have you used this product on the dash or other similar internal surfaces before?
I would never have used a solvent (even a mild one like mineral spirits) if I thought I had a choice, but not having a choice, I was lucky and things worked out perfectly.
