Japanese Tranny?
I had a 2007 Carrera S, and now have 2010 GT3.
I believe the gearbox in my GT3 is made by Getrag, and the one in my Carrera S is by Aisin.
Regards,
(P.S. With a quick search, this is from a Car & Driver article...
"...The stiff clutch and the high-effort shifter provide further confirmation of the GT3’s dedicated nature when you slip the transmission into first gear. The high shift effort comes in part from the short-throw linkage, which reduces by half the distance the shifter moves between gears. It also reflects that the GT3 uses a race-derived Getrag transmission with heavy-duty steel synchronizers, much shorter gearing, a dedicated oil cooling system, and interchangeable ratios, rather than the Aisin transmission used in other 911s...")
Regards,
http://www.gboxweb.com/997specs.html
1 Post
But what do I know, Mr. Gboxweb from Colorado sounds more creible than the Car & Driver magazine
What about fitting GT3 engine into a Carrera? I imagine it's a costly proposition, specially with electronics that has to be updated to work on GT3 motor vs. Carrera!
