ECU wiring diagram/help
does anyone have an ECU diagram for an '06 C2S (or 997.1 non-turbo)?
also, can someone with a similar model/year pls simply look under your ECU tray? (no need to remove or unbolt tray - if you pull carpet, you can see thru an inch slit, etc). i have 3 other plugs/ports, 1 female (labeled "AUX"), and 2 male ("DRIVER", "COMM") that are not connected to anything . does anyone have the same or know what these are for? should they be connected somewhere? i just want to make sure they are supposed to be loose.
