Error / Fault Code
Old Apr 21, 2012 | 04:16 AM
Gollom122's Avatar
Gollom122
2nd Gear
Default Error / Fault Code
Plugged in a durametric to check my fans were kicking in properly after I found a stone jammed.
It's identified a fault code on my car (C2S) which I need to understand.
P1682 - Secondary air valve final stage
Any idea where I can look this up or what might be the trouble if any - No problem with the car that I am aware of.
Old Sep 2, 2013 | 09:13 PM
cab83_750's Avatar
cab83_750
Anyone has info on this? I can't even find the part on the PET.
Thanks.
Old Sep 3, 2013 | 06:53 AM
CAVU's Avatar
CAVU
Using the search function I found this: https://rennlist.com/forums/997-gt2-...sb-re-rms.html go to post #7.
Old Sep 3, 2013 | 10:11 AM
Spiffyjiff's Avatar
Spiffyjiff
FWIW:
P1682
Electric exhaust flap
NOTE
Only for Carrera S increased performance (X51).
Short circuit to B+/ground or open circuit in the control line
Diagnostic conditions
---Power supply voltage > 7 V
---Engine running
---Switch exhaust flap on and off with button
Possible fault causes
---Open circuit of power supply to exhaust flap solenoid valve
---Exhaust flap solenoid valve faulty
---DME control module faulty
Old Sep 4, 2013 | 12:52 AM
cab83_750's Avatar
cab83_750
Thanks, but I saw that and unfortunately my car is just a regular 2007 C4S without X51 package, no PSE.
I could definitely can hear a clicking sound by the alternator (much like a switch doing intermittent on/off cycles). Additionally, the noise goes away AS SOON as the RPM rises above idle. Lastly, the noise is intermittent, and comes on as soon as the car warms up.
So far, we think it is part #2 on the diagram below.
File Type: jpg
Old Sep 4, 2013 | 12:55 AM
cab83_750's Avatar
cab83_750
Originally Posted by Spiffyjiff
FWIW:
P1682
NOTE
---Engine running
Would you mind letting me know where your error code description came from? My Durametric shows as:
P1682
Secondary-air valve final stage.
thx.
Old Sep 4, 2013 | 11:47 AM
Spiffyjiff's Avatar
Spiffyjiff
i have a pdf with (most) all the porsche 997.1 DME codes. i got the download link from somewhere on here a while ago along with a workshop manual and wiring diagram. i think renntech may also have a listing.
