Spacers advise
Old 03-30-2012, 11:06 AM
Dutchie in NC
Dutchie in NC's Avatar
Default Spacers advise
Thinking of putting wheel spacers in my 2007 997s, but I really don't know much about it... Wondering about the following:
- how much mm should I go with the spacers?
- do spacers effect driving/steering characteristics?
- should I do both front and rear, or just the rears?
- where is a good place to buy spacers?
Thanks!
Old 03-30-2012, 03:30 PM
Mumbles
Mumbles's Avatar
Suncoast products sells spacers.
Not sure if you have to upgrade to a longer lug nut ( could be expensive )
Good luck tho !
Old 03-30-2012, 04:03 PM
PTParks
PTParks's Avatar
Good luck tho !
Any spacer thicker than 5mm will require longer wheel bolts.
Old 03-30-2012, 04:32 PM
Skibum
Skibum's Avatar
Why are you thinking of getting spaced out?
Old 03-30-2012, 05:00 PM
FiatCoupe
FiatCoupe's Avatar
The 5mm spacers I bought from Suncoast included new wheel bolts and locking bolts
Old 03-30-2012, 05:02 PM
zanwar
zanwar's Avatar
The 5mm Porsche package looks good and comes with everything you need. I'm running it right now with 18" rims on my 4S. There is a more aggressive Porsche spacer you can put on the back, something like 17mm I think. It attaches to the hub with your stock bolts, then the wheel attaches to the spacer. I tried it for a while and it does make the car look very aggressive, but the bolts (studs?) have a different appearance and I didn't like that. The car is a little sharper after installing spacers but you stop noticing within a day.
Old 03-30-2012, 05:31 PM
AP997S
AP997S's Avatar
7 mm front and 15 mm rear seems to be the spacer of choice on a NB 997's.
I had 5 mm Porsche OEM spacers before I swapped them out. 5 mm just didn't look that much different compared to no spacers.
Old 03-30-2012, 05:42 PM
GolfTango3
GolfTango3's Avatar
I bought mine from Dave Martin at http://www.wheelenhancement.com/
Phone number is (310) 836-8908
He knows spacers. Awesome price and great service.
Old 03-30-2012, 05:45 PM
AP997S
AP997S's Avatar
H&R makes both spacers and longer bolts.
Automotion.com is a good source if you go that direction.
Old 03-30-2012, 06:14 PM
Alan C.
Alan C.'s Avatar
Received 1,049 Likes on 540 Posts
I used 7 and 15 on my 09 C2S and they filled out the wheel wells. I'd use longer bolts with any spacer. The total thread engagement is there for a reason. You put a lot of load on a wheel in a corner.
Old 03-30-2012, 11:32 PM
rickmdz
rickmdz's Avatar
what spacers do on handling? Can you only put them on the front to reduce understeer?
Old 03-30-2012, 11:52 PM
Dutchie in NC
Anybody ever dealt with these guys... any idea if these spacers would be any good:
http://www.ebay.com/itm/2pc-15mm-Fla...34dd26&vxp=mtr
Old 03-30-2012, 11:57 PM
AP997S
AP997S's Avatar
I'd be cautious buying 'off-brand' spacers especially on eBay.
I suggest buying from a recognized manufacturer (like H&R) to reduce the chance of problems. They might cost you more but they're great quality and proven.
Old 03-31-2012, 09:33 AM
Poly
5th Gear
Poly's Avatar
H&R make good quality spacers. Their made in Germany. 7mm front and 15mm are perfect fit for the 997. You will need longer wheel bolts.
Old 04-02-2012, 01:42 AM
Hammer911
Hammer911's Avatar
I also recommend the guys at Wheelenhancements.com, who were recommended to me by my P dealer for my spacer/wheel setup for winter.
Quick Reply: Spacers advise
