Shortshifter and LSD as options on 997.1 TT
Hello, everyone
I am looking for a 997.1TT, manual, and sometimes I see that some cars have a shortshifter and/or LSD installed from factory.
I do not do any track, just use cars as daily drivers all year round and sometimes go for spirited driving in the mountains.
Therefore I wonder if these options are critical when buying a 997TT.
Is LSD important at all and what advantage does it bring?
Is the gearshirft without shortshifter much longer and looser or is it still perfectly ok not to have a shortshifter?
Thank you in advance for your help!
Newbies Hospitality Director
I recently added the OEM short shifter to the CPO 2010 C2S I purchased about six months ago. I LOVE it. Tighter, shorter shifts. What's not to like?
It is not the question of liking, it is just that some interesting cars do not have these options (most often they do not have the diff, but sometimes also the factory-installed shortshifter is missing) so I wonder if that should be a deal-breaker for a guy who loves manual transmission and likes spirited driving in the mountains.
My plan is to get both when I'm ready to pull the trigger on a 997.2 S.
I found the standard shift great, no slop. Unless you've tried the short shift you'll be happy with it. I fitted one and would not go back.
Don't write off a car just because it doesn't have a short shift kit. You can buy one later about $430 USD and it's a relatively easy swap and is also reversible. You replace the entire gear lever end of things under the rear center console not the linkages on the gearbox.
The LSD option is another story. Quite some time ago I believe it was RonCT who did a nice write up on LSD. If I recall correctly, and someone please correct me if I don't, the gist of his post was that they do wear out and the efficacy of an LSD is debatable, particularly if you track the car. I've had cars with and without LSD and I honestly can't tell the difference but that's probably because I'm not a good enough driver. (My current car has it b/c I wanted Sports Suspension and it was basically a no cost add on. - imagine that, Porsche and a no cost add on - that can't be right.) For me, I wouldn't really care if I had it or not, and I do track my car a few times a year. Better drivers may feel differently.
