Heavier oil to protect IMS?
Old 03-19-2012, 04:53 PM
Palmbeacher
Palmbeacher's Avatar
Originally Posted by Zeus993
Anyone know if using a heavier oil I.e. 20-50 vs. 0W 40 will protect the IMS? This was suggested by a Tampa Bay Porsche guru... Comments?
Well...follow his advice and the engine might very well seize-up before the IMS can fail See, this is the problem when mechanics try to pontificate as if they were engineers. Mechanic=trained Engineer=educated. Big difference.
Old 03-19-2012, 04:55 PM
Zeus993
Zeus993's Avatar
Received 1,274 Likes on 587 Posts
Originally Posted by sullivas
BTW, Amazon has Motul online for ~13.00/QT. Any I think it is available in jugs as well.
That's still higher than I paid at Lordco. I know that every now and again there are auto shops that have sales. Anybody know of any going on right now?
Old 03-19-2012, 05:04 PM
Neotorque
Neotorque's Avatar
Originally Posted by alexb76
On another note, he said if you got pre-2005 model with old bearing, it IS going to fail sooner or later and recommended folks to just bite the bullet, do a $2000 IMS upgrade and prevent a $20K damage, however he said for post-2006 cars the failure is so low (none he's seen in our city), that just by using good oil and right maintenance it should be fine for the life of the car.
All engines will fail "sooner or later." For ~99% of the M96/M97s out there, it seems to be "later."
That's not to say that people shouldn't do an IMS upgrade, especially if it helps them sleep better at night, but it's a bit of fear mongering to suggest that the engine that powers a number of Consumer Reports most reliable cars, including the Boxster which came out on top of all other cars for the last decade, is a ticking time bomb.
Old 03-19-2012, 05:23 PM
Zeus993
Zeus993's Avatar
Thumbs up
Totally agree. Winter's over. Time to get off the forums and go play outside.
Old 03-19-2012, 08:28 PM
alexb76
alexb76's Avatar
100% agreed... however, if you have a 2005 and you HAVE the option to upgrade, why not? It's $2K or so, and while doing it, might as well do the clutch.
So, I guess the advice is, if your clutch is close to need replacement, might as well do both, as clutch labour is pretty much covered while upgrading IMS. He also said, if you replace clutch early, you have a chance to save the flywheel from replacement and save around a $1000.
Old 03-19-2012, 08:38 PM
Edgy01
Poseur
Edgy01's Avatar
The best thing you can do for these cars is to drive them. When they are babied they do far worse.
Old 03-19-2012, 08:43 PM
Neugene
Neugene's Avatar
I just bought an '05 997 and had it gone over by the local specialty shop. They told me that everything was in great shape and that I need not worry about the IMS issues. That initially gave me "warm, fuzzy" feelings. However, after reading many posts on this subject I am not sure. On one hand the clutch is in good shape and I don't want to fork out $2k if it is not needed. On the other hand, I really do not like to think about the cost that would be incurred by an IMS failure.
As far as the oil weight question, my father was an auto mechanic as well as a jet engine mechanic in the USAF. Back in the day when I was wrenching on muscle cars he swore by Castrol 20w50. As I progressed into more modern cars I never thought about changing oil weights. After all if the 20w50 was good in a 400hp small block chevy then it had to be good in a modern 250hp 6 cylinder right? Well, he explained it this way (and I think it makes sense,) the older engines were made with looser tolerances. With modern (computer controlled) lathes and milling machines the tolerances in an engine are now much tighter. A gap that might have been 0.01" to 0.02" in an older engines can be held to 0.002" or tighter now. The thicker, higher viscosity oils cannot flow through these tiny gaps as well as the thinner, lower viscosity oils can. Therefore you need to use the thinner, lower viscosity oils in modern engines.
Please, correct me if I am wrong but this is the way I have understood it to work for some time now.
Old 03-19-2012, 09:08 PM
Alan C.
Alan C.'s Avatar
Received 1,058 Likes on 545 Posts
Steve,
Thanks for chiming in.
Old 03-19-2012, 09:29 PM
Neotorque
Neotorque's Avatar
There are two reasons I haven't done the IMS upgrade. First, and most important, I bought an extended warranty through Fidelity, and heaven forbid anything happen to the car, I do not want them to claim that an aftermarket part contributed to it.
Second, and admittedly less importantly, I don't think there's anything really solid, at least that I've seen, that actually proves the LN unit is a substantial upgrade over the stock unit. I'm certainly not saying that it isn't, I'm just saying it seems like most of the information on the Internet is highly speculative, at best, and that makes it difficult to make a real assessment of how effective something is. There's no double-blind studies showing the difference in fail rates with the two systems. We know there's a very low fail rate with the LN bearing, but we also know there's a very low fail rate with the stock bearing. Now that LN advises swapping it every 5 years, or whatever, is there any reason to think the stock unit would do meaningfully worse if swapped out every 5 years?
I'll probably do the upgrade when my warranty is up, but I'm hoping there's more data to substantiate its effects by then.
Old 03-19-2012, 10:25 PM
alexb76
alexb76's Avatar
+1 to that, he also said when car's not driven, oil just sits and leaks around the bearings.
Quick Reply: Heavier oil to protect IMS?
