93 octane requirement - How does lower octane effect the car
You did the right thing experimenting with different gasolines and if you have found the car likes BP or Exxon or Sunco then feed it one of those gasolines.
Sincerely,
Macster.
There are only a few reasons why living in New Jersey could be better than living in California - and Utkinpol has pointed out one of them! (of course, a second reason is that we have an abundant supply of 93 octane gasoline)
I don't have this problem on georgia, but are octane additives a no-no?
Octane does not equal quality so i am not sure if the additives of these bottles differs much from what they are adding anyway.
Any thoughts on that to help the cali peeps?
Couldn't find 93 during lunch last year at Mosport. Gave up and filled w/91. As it had finally stopped raining, put on the Hoosiers. Next time out, actually lost time up the back straight. WTF?? Oh, yeah, I put in 91.
Probably won't notice street driving. But you sure will on the track.
I don't think there's a simple answer to that. It's obviously not due just to the CA requirement for cleaner burning oxygenated fuels because the higher octane unleaded fuels are still legal and available; I can buy them at my local track and a few stations do carry them. I suspect issues around availabilty, refining capability, and cost are at least as, if not more important.
I guess we're lucky here, as have Chevron 94 octane option with 0% ethanol!
Oh boy...I forgot about Exxon Valdez. Time to buy and electric car or convert my 911 to run on natural gas.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I haven't bothered to work the numbers, do the math, but I suspect it is quite a bit cheaper to simply buy the right octane grade of gasoline.
Now I realize you (like me) are in CA and 91 octane (barring the rare station that carries something higher) is all there is.
But both of my cars appear to have been unaffected to any noticable degree by running 91 octane.
To bump the 91 to 93 I think you'd have to buy a lot of octane booster. I've not looked into this, only going by what others have posted, but the octane boosters raise the octane not by full points (from say 91 to 92) but by a tenth fo a point, from say 91 to 91.1... If this is correct it is going to cost you a pretty penny to get to 93 from 91 octane.
The only time I use an additive is when I use Techron and I only use this every couple of years, for instance a month or so before one of my cars is due to be smogged.
However, the Boxster is due to be smogged in May and the car/engine is running very well and I think I'll skip the Techron this go 'round.
I might point out the Boxster is running very well at over 250K miles. Due to a sick relative I've been driving sometimes 100 or more miles per day sometimes several days per week and there for a few weeks almost every day! 700+ miles per week of driving.
The Boxster appears to have taken to this like a duck takes to water. The engine is running as good as it ever has. Too give the Turbo some exercise it gets the call every few days and it loves this 100 mile jaunt too.
I'm telling you people these cars love to be driven!
Sincerely,
Macster.
It's a supply issue. Every gallon of oil distilled can only produce so much high octane gas. When it's refined, if you take out the really good stuff to make 95 or better, the stuff you're left with is only about 85 octane. So they create blends to bring the minimum octane up to the usual minimum of 87, and 89. With only so much of the lighter stuff to go around, there's a limited supply of it available.
In the midwest, filled with pickups and low-rent domestic sedans, the demand for 87 is pretty high. That leaves more of the good stuff available to be blended. They can make higher octane because more of the lower octane is being used up, leaving more of the good stuff available. In California, full of Benzes and Bimmers and turbo cars, the demand for 91 / 92 is higher, so there's less of a supply of that good stuff to go around. Thus, the blend has to include more of the lower-grade stocks.
Hope that made some sense.
+1 In Ontario I have to use PetroCanada (a Suncor Co. now) Ultra94. Car runs much better on that, unfortunately, than Shell91. Lately have noticed some PetroCan stations have shortages of 91 and 94.
