Engine Load via Garmin
Even though both my cars have factory GPS, Santa Claus brought me a new Garmin Nuvi 3790 LMT. I was going to return it until I read the literature with it and learned it was also a Code Reader/OBD II scanner. I bought the transmitter that plugs into the OBD II port and low and behold in addition to giving any codes that are set it also reads various engine parameters as you drive.
Now the question. One of the parameters reported is Engine Load. This is reported as a per cent. I would like to know what it is measuring. When the gauge reads 50% load what is it measuring and how is it measuring it? Mass air flow, coolant temp, etc. are all understood, but I don't understant what or how engine load is being measured and what it means. Any of you engineers out there have an answer?
Gary
California Air Resource Board (CARB) defines this as airflow divided by peak air flow. Peak air flow may be adjusted for altitude via barometric means if available. For diesel engines, the number is current output torque divided by peak output torque at current rpm. We have noted that vacuum leaks can have dramatic effects on this value.
and even more detail here :
http://obdcon.sourceforge.net/2010/0...ed-load-value/
Calculated Engine Load
Gary
It does vary during driving. Some interesting, to me at least, observations are that driving my PDK in auto results in significantly higher (about 20 or 30%) readings than when I'm driving in PDK manual mode.
