Once an RMS, always an RMS?
I have what is hopefully an easy, quick question:
Is a car with a properly repaired RMS more prone to future RMS leaks than a car that hasn't had an RMS leak at all? Or does the repair make it "good as new?"
- Mike
- Mike
Form what I read about the issue. If you have an RMS problem and it gets repaired properly with the newer type seal it resolves the problem in a large majority of cases. But I'm sure there may be a few who had it done more than once.
FWIW... I have an early build '05 C2. RMS has been dry without issues.
As to your question - well it depends on the cause of the RMS leak. Sometimes there was just a problem in the install of the gasket, or it got damaged somehow. In that case, the fix is permanent.
In other cases, the problem is actually an imperfection in the case, or that the case is flexing under load or changing too much with temperature or something like that. If that is the cause, then replacing the seal is just a band-aid and it will leak again soon.
These recurrent bad RMS leaks seem to mainly plague the generally great GT3 engine, not the normal 997 so much.
Frankly I worry more about the too many multi-thousand pound barely guided cruise missiles on wheels driven (Hah!) by some butthead on a cell phone around my Porsche than I do about RMS (or IMS) issues.
Sincerely,
Macster.
I had my then new 99 996 RMS replaced at 6000 miles in 1999. Never leaked again. Traded it in this last Nov with 50000 miles. Since this was replaced with an early seal, we know they tried a number of versions, I think a lot has to do with the quality of install.
