Tires 305/30ZR/19. Vs. 295/30ZR/19
Old 03-20-2013, 03:52 PM
Niac
4th Gear
Niac's Avatar
Originally Posted by stefang
Tires always have a range of wheel widths that they're good for. If you look on tirerack, they have the specs for all tires. Traction tends to be better if the tire has a slight trapezoidal form on the wheel, so going too wide can be detrimental. Lobster claws are 11s, no? So they would have a stock size of 295s. If your concern is looks, get some spacers.
I guess having 295 and 305 doesn't matter then, unless you want the looks
Old 03-20-2013, 04:28 PM
speedy88
speedy88's Avatar
Be cautious if it is an all wheel drive model as I heard and read the the rolling circumference between the front and rear tires has to be within factory's recommendation 4W system to work and maintained correctly (especially on 997 models).
Old 03-20-2013, 04:48 PM
dasams
dasams's Avatar
Originally Posted by Mumbles
I believe that the 4S cars have the wider stock rims than the regular 2S or Carrera
Not true but the offsets are different. As noted above, the Carrera Sport wheels are 0.5" wider and NB cars so equipped were specced with 305 tires in the rear. The 4S got 305's in the rear for all wheels. This per the 2009 Tequipment catalog (google it). Dave
Old 03-21-2013, 06:50 PM
Mumbles
Mumbles's Avatar
Thanks for the info Dave
Quick Reply: Tires 305/30ZR/19. Vs. 295/30ZR/19
