Coolant light question
8.5 gallons of coolant so I imagine it has to be a lot lower than below the min line. Have you ever seen the size of the resevouir - it goes pretty far back into the engine compartment.
You shouldn't be losing coolant. There's something causing this. If your level is dropping, there's a good chance you merely need to replace the cap with a new one. I drove around for a few years with a coolant tank that was chronically an inch or two low. I had the dealer check for a leak or engine problem. Couldn't find anything. But when I would top off the system, it would always run down a little low. Finally I read something here on the 996 forum about the coolant caps becoming defective. And sure enough, I replaced my cap with a brand new one and the level hasn't moved from full since then. I think it cost me about $16.
