Crashed the 997 in the rain...
Anyway, do I need to be ready to discuss a diminished value issue with them in the AM? How about loss of use?
Oh, I'm in Austin. Where do I get it fixed? I assume Farmers will have no idea how to fix a car like this.
There was a thread titled "Diminished Value" last month. To sum it up, the concensus was 10% -20% reduction due to an accident. Of course getting that could be another story.
Good Luck
Ken
http://berlisbody.com/
Sorry bout your car but whomever fixes it make sure they do it right and have worked on Porsche's before otherwise you may have "other" issues. Also remember that your idea of properly repaired and the insurance company may differ so be prepared! GL
But my car incurred some significant damage and it's not as simple as using the body shop that Porsche recommends. Consider them but do your own investigation. I visited many body shops including the one my dealer recommended and was not satisifed with any of them including the dealer recommendation but I felt stuck with them.
Then while on another forum someone (lovely, generous and caring people that populate out Forums for the most part) suggested one that I called and spoke with and they have my car now and I'm thrilled that they do. They've been wonderful and their customers rave about them all over the internet.
A few years ago a good friend of mine and a salesperson for Porsche who sold me many cars over the years told me something that makes a lot of sense now. He said to me "Tom if you drive 12-15K miles a year you can't own a Porsche......lease them but don't buy them because if they get hit and you own them you're screwed. Buy a Porsche when you're retired and drive 3-5K a year"
To which I said "then I won't be able to afford one" but that's a different discussion.
I was going to disregard that advice and buy my current Porsche at the end of the lease but obviously my plans have changed.
Good Luck to you and I know you'll have your baby back soon.
Tom
About diminished value. My response would be to strive to find a suitable place to take the car so it is fixed right and comes out with as little DV as possible.
As for whether the ins. co with go along with the DV... hard to say. In some cases DV is excluded in the fine print.
Farmers like most ins. co's will want you to take the car to a shop with which it has a business relationship. This may not be a bad thing as most ins. co's do business with almost every body/repair shop at some time or another.
A risk of doing business with a shop that gets alot of its work from any one company will be the shop will be under pressure to cut corners in repairing the car.
Some shops are better at dealing with this pressure than others.
You want to make sure you take the car to the best shop, one that will see the car is repaired correctly. In CA the wording as something like "as good as humanly possible."
Search for a shop that is a Porsche Approved Collision Center.
Briefly, the shop will partially tear down the car, removing the front bumper cover, the wheels/tires and putting the car on a Celette Bench. On this bench the shop will then determine how 'bent' the car is, which hardpoints (if any) are out of position. (Porsche's tolerance on the location of these hardpoints is quite tight.)
It is at this time the most accurate estimate of the damage the car has sustained will be made and the most accurate estimate of the cost to repair the car made. It is not uncommon for the initial estimate to double or more.
To keep any factory warranty in effect the car must be repaired by an approved shop. The replacement parts must come from PCNA. No salvage or aftermarket parts allowed. The parts must be bought through a Porsche dealership. The parts must be installed by a qualified Porsche tech and any related systems -- like the cooling system or the A/C system -- must be worked on by a Porsche tech. Body shops are notorious for not doing this work right. They know their body/paint work (or at least the shop you choose should know these) but for mechanical systems you want a Porsche tech working on those.
Before the car can be declared road worthy a Porsche tech will have to examine the car. At this time he can advise you if he finds any repairs not up to snuff.
I had my Turbo treated to this and in fact had the Turbo's front bumper cover removed by a tech at a Porsche dealership and the tech spotted several issues 'hidden' under the bumper cover so back the car went to the body shop.
Clearly, the body shop had failed to have the car's hardware under the cover done by a Porsche tech. I raised a bit of heck with the body shop and the dealer which I had trusted to oversee this work and the car came back in perfect condition.
Unless you have rental car rider or loss of use rider with your policy you will probably be on the hook to supply yourself with a car while your car is in the shop.
If the other driver is at fault and of course he and his ins. co accept responsibility, you can approach the other ins. co about getting a rental car to use while your car is in the shop.
Sincerely,
Macster.
