stupid question about tpms
Old Jan 4, 2012 | 11:12 PM
Domer911's Avatar
Domer911
Default stupid question about tpms
how the hell do I get from the variance (+ or -) readout to the actual tire pressure readout? I feel like I'm losing it...
Old Jan 5, 2012 | 12:16 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
I would try to help you but it might have changed in the .2 models.
Old Jan 5, 2012 | 02:51 AM
Mike in CA's Avatar
Mike in CA
I think you've selected "info pressure" and are a couple of levels down into the TPMS menu. Pull the computer control stalk towards you 3 times which should get you back to the main display and the actual tire pressure readout.
Old Jan 5, 2012 | 04:12 AM
simsgw's Avatar
simsgw
Yep, as Mike says. And when you reach that top level push the lever up or down (your option) until the tire pressures appear. The delta values only appear when you're sittijng still, so they are buried in a sub-menu. The actual pressures can be read while driving. You can watch the effect of cornering and even sun shining on one side.
Gary
Old Jan 5, 2012 | 09:07 AM
Domer911's Avatar
Domer911
thanks for the feedback. That was it, I just was too far in (regular problem for me). I only had to toggle out. whew.
