Help! Can't get car into gear
Gary
Gary
It is 100% not necessary to do this. Does it save a touch of wear on the 1st gear synchro, probably. Furthermore, this has nothing to do with the "porsche" transmission, which is made by aisin anyway.
If it shifts with the car off, something is likely causing your pressure plate not to fully disengage the disk.
People not accustomed to sports cars take the car out of gear approaching a stop and leave it in neutral. That allows a random placement of the gear teeth. Experienced drivers prefer not to do that. It's a pain having to use second gear and a little clutch to substitute for foresight. Instead, we engage first approaching a stop even if we never let the clutch out. Once the car is completely stopped, we take it out of gear, but that leaves the teeth aligned.
If someone forgets to do that, the teeth usually still align close enough to move into alignment from the pressure of the synchros, but once in a while they don't even when the car is warmed up. When the car is cold, the alignment has to be closer to shift into first with reasonable force, so it's just easier to develop the habit and use it all the time.
The fact that the problem doesn't arise when the car's been shut down means nothing. Almost everyone leaves the car in gear at shutdown and all the experienced drivers do. That serves the same purpose.
I don't say it isn't the pressure plate, I just think it's smarter to expect horses when you hear hoofbeats, not zebras.
Gary
Thanks Gary
Gary
