Problem filling fuel tank? Or...
1 Post
Just go to your dealer and ask them to install this 'adapter.' (edited: thanks forumer 'function12' for the correction, below is a newer picture with the gas cap removed, so we can see the crown-like black ring adapter around the filler neck.)
Now I can go to any gas station, use any pump, and fuel up as much as I like.
With best regards,
With best regards,
![Name: 997cap1.jpg
Size: 49.3 KB](https://rennlist.com/forums/attachments/997-forum/1208717d1501366363-problem-filling-fuel-tank-or-997cap1.jpg)
![](http://i227.photobucket.com/albums/dd162/axhoaxho/997fuel1.jpg)
That is NOT it.
It is a black ring that slide over the outside of the filler neck. The top side of the ring has little humps. Almost the a crown. I will see if I can get a pic later today.
Had the same issue with a new C class Mercedes this week in So Cal. The new nozzles don't seat properly on the filler neck. I had to push the nozzle as far it would go into the filler neck for the entire fill, and was able to get a full tank.
With best regards,
![](http://i227.photobucket.com/albums/dd162/axhoaxho/997cap1.jpg)
With best regards,
That is the part exactly. (notice the black plastic ring around the metal fuel inlet)
I took the car to the dealer, complained about the premature fuel shutoff and they installed the adapter for free. If you are out of warranty, I imagine it would be cheaper to order the part and install yourself.. though it might be worth checking with your dealer about what the part would cost.
Its not just the Porsches. My 2002 VW New Beetle has the same exact issue. It may be the result of some EPA maroon assuming that all americans drive Detroit or Far East origin cars that have some difference in the way the fuel tank entry is designed, or just bad luck in my choice of cars. The idea backfired for the state of Washington as on a refill in the summer, having to constantly press then handle again to work my way from 1/2 tank to a full tank I ended up dumping a couple pints of fuel on the ground as the tank eventually overflowed.
Im glad i seen that i wasnt the only person who this was happening it too. I live in the central valley(Fresno,ca) an i felt like the kid who took daddys porsche out for a joy ride. Maybe its a california thing?
Gary
Same problem here, Gary... I started tilting the nozzle a bit during fill, (in effect, pointing the inserted end of the nozzle downward), however, all of this 'filler ring adaptor' fix stuff may just be a moot point soon in Cali. I read recently that they are doing away with the little mechanism that allows you to pull the trigger and walk away. I've already seen it missing in a couple of my favorite gasoline haunts. We'll be standing there holding our 'nozzles' for the entire fill soon.
I did find an alternative to that little clip that lets you walk away while the tank fills. Patronize a new/old establishment called a surrvis stachun [sp?]. They have minions who dash up cheerfully and clean your windshield as well as filling your tank with liquid fuel. Charming. Unfortunately, I think the business concept is a local custom of one of the quaint towns I visited on this trip. I've only seen the one example in Pebble Beach, California along a pretty lane they call "17-Mile Drive" and I suppose it wouldn't be worth driving there from my home 328 miles away.
Gary
My favorite place already has. The problem did not go away though. Even held by hand, the car won't accept more than about 2/3 full until you add the widget Porsche designed. (Which I suspect entirely defeats the purpose of those new nozzles. That doubles the pleasure of having one installed.)
Gary
Gary
As for the 17 mile drive, I have been on that beautiful road. The entire peninsula is pretty spectacular as a matter of fact... from Carmel Valley to Pebble Beach, to Monterey... but I digress. It seems that I need to get one of those little 'doohickeys' for my fill neck.
