Grinding noise
Im hearing a grinding noise when braking. The outer pads have plenty of meat on them and the rotors look good. What gives? Could it be the inner pads that i cant see? I have 13k on the ODO. tks
Poseur
Are you a long time Porsche driver? If not, you need to be harder on the brakes. Brake LATER, and HARDER. See what happens. The problem should disappear. Sometimes it's the build up of a blaze on the surface of the rotors from soft braking, and sometimes it's when a piece of rock gets flipped up and lodged between a pad and rotor.
well thats the thing. I would expect squeaking and not grinding w/ soft brake use but i was at a DE about a month ago and used them pretty hard.
Poseur
Possible rock stuck in there. If you have easily pull the wheels do so and then hand-turn each hub to isolate which one(s) are noisy. Then explore a bit more. You can pick it out with something like a horseshoe pick or a screwdriver.
Happens every time I wash my car. Rust on the rotors. Also happens from glaze if I don't brake heavily for a while. The rear brakes are the most prone to this. It is normal. Brake hard and it goes away.
if not - inspect if calipers shifted from their proper axis.
