Fidelity Road Hazard Tire and Wheel Coverage
After hitting some debris on the freeway, I found out that my left front wheel has a large flat spot on the inside of the wheel. ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Interesting thing is the tire never blew.
Then I remember that I was one of those who fell for the Tire and Wheel Road Hazard coverage from the dealer I purchased the car.
I called them the other day to file a claim and was told that unless the tire was damaged they dont cover the damaged wheel. WTF kind of crap is that. I admit its odd that the tire didn't blow with such extensive damage to the wheel but what a scam.
I will be calling the dealer today because I know for certain that was not how it was presented by the finance person.
The tire was scuffed on the inside at the same location as the flat/bend wheel.
mjsporche--- Did you contact Fidelity ? When I spoke to them they explained that in some cases the dealer will include a clause that will included wheel replacement even if the tire is not damaged.
I still think this is all BS. Its not curb rash. The car is not drivable in that condition which in my opinion should fall under the coverage.
That's why you have to read the fine print on these warranties. Maybe some of them will cover any type wheel damage, but my experience has been that many will only cover wheel damage if it is bad enough so that the tire won't hold air. So a bend or scrape will not be covered.
Of course the sales guy pushing this to you at the time of the sale tells you that everything is covered. He probably hasn't even read the policy. Remember, in life the large print gives you things, and the small print takes them away!
For those that have the policy and get a no response, you might ask them to refund the balance of the policy. Yeah it is refundable, prorated.
Good luck, hopefully you can get your dealer to help you out on this one.
I've never taken the tire/road hazard option on any of my extended warranties, so I don't have any experience with it. All of my extended warranties so far have paid for themselves and then some. I'm 6 months into a 6 year exclusionary warranty on my '05 and it's already paid me $1300 in two fairly minor repairs (a starter cable and the shifter cable). That said, I didn't get the Fidelity warranty my dealer was selling, for two reasons. One, there was a clause in it that said failures due to wear are only covered until 50K miles, and that struck me as a way-out for them to try denying just about anything up to and including engine and transmission failure. "That IMS bearing wore out, the car's got 51K, so, sorry dude you're SOL." The other reason was, it cost almost twice as much as the one I did buy.
If it were me I would push the issue. Be a squeaky (dented) wheel, and they might do something for you just to get you to shut up and go away. Lots of times companies try to give the brush-off, and for the majority of folks it works. For the minority who don't take it lying down, there' usually some "goodwill" forthcoming.
But, do whatever makes you sleep better at night.
PM sent to Palmbeacher as to who you have as to your extended warranty company.
Thanks.
