Exhaust Header Damage
They want to replace the system at a cost of approx 3k
They don't leak, Can they be repaired or does it really need replaced or should I do nothing?
If you're in a .1 997 get yourself a set of these:
http://www.suncoastparts.com/product...de=997sexhaust
Easy DIY in about 90 minutes.
Reality is that most factory pipes have bends and dimples due to manufacturing and restrict air flow to create some backpressure. Im sure the aftermarket exhausts are mandrel bent.
It would take a pretty good blow to bend those exhaust pipes. And if they are bent the undersides should show the scars of the impact.
And a quarter of an inch?... that's not much.
As long as the exhaust system is leak free and makes no sounds that suggest it is out of position or making contact with parts it shouldn't, that the hangers are secure and well the system is just in otherwise fine shape, I'd be tempted to let it be.
Before I'd spring for $3K of exhaust system I'd have to have clearer signs that this expense is needed other than a quarter of an inch out of position...
Oh, as others have mentioned, pics would be nice. I'd like to see what the exhaust exits look like relative to rear bumper cover and a snap shot of another car's rear for comparision would be nice too.
Sincerely,
Macster.
