Stock C2S on the Track
I would suggest fresh oil (before or after depending on the last change) and high temp brake fluid. Other than that make sure your tires are in good shape with the proper pressure and that you have sufficient brake pads/rotors left. And of course, slow in/fast out, stay relaxed and have fun. Remember, it's not a race and as long as you and your car go home in one piece, you won.
I've been doing DEs for 10+ years, and my stock '09 C2S with PDK still challenges me to do better every time I take it out. The only things I've changed are tires - Pirelli P-Zero Corsa which are really sticky but not R-compound and better brake pads (Ferrodo DS2500).
I WISH I could drive this car to it's limit.
Moderator
Honestly, the only things you really need are:
1. Alignment, but not by the dealer, by an indy that knows how to set up a C2S for dual use. Depending on the C2S you buy, you could probably get upwards of -1.3 degrees camber up front, which will sharpen the steering and help reduce understeer.
2. Good brake fluid, like Castrol SRF. With this in the system, you will never have to worry about boiled fluid.
Stock pads are amazingly good and in many ways the tires are the limiting factor, not the brakes.
I've had my share of cars and students and I've been amazed at what a stock C2S (my own included) or even a stock 964, 911 SC, etc. can do at the track.
Get an alignment and better brake fluid. I never had any problem with Super Blue or Motul 600.
Most tracks have more right turns. The puts a lot of wear on the driver's side tires. I used to wear the outside shoulder of the front wheel before I got more camber in the car. Swapping tires side to side extends their lifespan.
Pagid Blues are a good compromise for street/track once you wear out your stock pads.
Have fun. The car is more capable than you. As long as you know that, believe that and respect that along with listening to your instructor you will be fine.
Moderator
You won't need to think about brake pads for a while and I had a terrible experience with Blues. There just is no such thing as a compromise pad. Either it's a street pad or a race pad, nothing in between. Every track pad sounds like a school bus on the street, so if you are going to really get into this, understand you will be swapping pads out before / after track events far in the future. I say far, because you probably have 2+ years of learning before you are going to have to worry about pads. And for fluid, I'd stay away from ATE Blue / 200. It's about the same as Porsche OEM and the problem with Blue is it stains and makes it obvious you "tinkered" with the car (ie: Warranty). ATE 200 is the exact same fluid, just without the stain. Motul and Castrol SRF (what I use) are far superior. With SRF I flush once in the early spring and don't have to do anything all season long (10-12 days at the track at Instructor pace). Costs more, but the savings in time and multiple flushes, bleeding, etc. is priceless.
Get yourself as good an alignment you can, get the fluid freshened (you will need the fluid done to pass tech anyway), and go have a good time
Ron, i did this whole season on front 'EBC yellowstuff' pads and they are acceptably ok for relaxed driving. it only starts to feel that rotors get too hot for them when i drive in advanced scda group with not that many cars on a track, but for regular PCA event with a lot of traffic EBC seems to work fine. obviously it depends of a track, both NHMS and Lime Rock are easy on brakes, but i had stock pads fading consistently at NHMS - it never happened with EBC pads. I think for people in beginner groups those pads will work fine and they squeek much less than PFC or pagids.
Keep your car stock and you will do just fine. Porsche sport driving school uses stock cars on stock tires and brakes.
http://www.porschedriving.com/Sports-Driving.aspx
Hi there
The C2S is awsome on the track, here is me:-
Thats a 2006 C2S with X51 manifolds, PCCB, Aerokit, PSE, Michelin PS2, my best lap time so far is 1:25 and a friend in a 997.1 GT3 who is a very good driver is doing 1:22 and he is also on Corsas.
So needless to say I am very happy with the C2S. With Corsa or CUP tyres and a remap I can see times dropping to 1:22-1:23 and the rest is then down to me improving my skill behind the wheel and braking a lot later.
Thanks guys. I would like to get to a point where I can drive like the guys on Top Gear. They look like they have an absolute blast driving and sliding around the track. I guess they are usually testing stock cars so that is a plus.
