A/C Memory in pcm not working properly
Seems like i cconstantly need to reset the A/C memory every few day's. Any quick fix? TY
Assuming you have Sport Chrono, are you going into the Individual Memory setting on the PCM and setting Individual Memeory while the A/C is running at the settings you want? If it's working properly, A/C then should start up at this setting every time.
Yes i have sports chrono. I set the a/c to where i want it and hit "a/C memory" then "store" seems to work for a few day's then i need to reset it.
No using same key. Thx
I've had occasional cases of the bladders in the seats inflating for no reason and pressing the seat memory buttons would then reset the seat. Seems like the 'settings' only affect how things are set when a 'set things now' event occurs. After that, it appears, settings can 'drift' in the various parts of the car that have settings.
