OEM CL wheel spare for your trunk !
Guys,
I may be the lone member of the CL Wheel Appreciation Society. I have had them off and on, and the procedure is quite simple……..love the look too, anyway.......
Check out OEM CL wheel spare for your trunk.
Looks like it consists of an adapter plate and special lug nuts and the wheel....
You can also get the OEM scissor jack and foam enclosure that goes under the trunk floor piece. The foam cut-outs hold the jack and jack lever.
The price is unmentionable in print, as it may cause seizures when assimilated.
I would also imagine that it will not fit on a car with PCCBs. That's the case with the normal 5-lug wheels. The spacesaver spare wheel will not fit over the massive PCCB brake rotors and calipers.
