Torque Wrench and Lug Socket
You don't want too much anti-sieze, just a little. I use Permatex anti-sieze, which is aluminum paste.
"Always apply a thin coat of Optimoly TA (aluminium paste) on the thread of the wheel bolts, on the shank and between the bolt head bearing surface and spherical cap ring (under the head) -arrows- . Do not grease the spherical cap bearing surface -X- of the wheel bolts that face the wheel. "
You should not install the bolts without the antiseize in place (either existing or newly applied) and as said, you should not apply too much.
The reasons for the anti-seize are:
- Prevents the bolts and hubs/rotors from becomming pressure/friction welded together.
- Provides the correct interface for the torque numbers when tightening the bolts.
If you don't have anti-seize, or way too much anti-seize and in the wrong place (such as on the bolt shoulders in the pic above) then the torque values are not going to be correct, and the bolts may work themselves loose prematurely.
left out a biggie...
I believe its Griots that sells brass hole pins that thread into the carrier. Use two and it makes re-mounting your wheel a snap. Otherwise prepare to frustrate yourself a bit getting the first lug or two in...
they are brass so they're soft and wont scratch your wheel
