time for new tires, sizing question for 997.2
Old Jun 26, 2011 | 10:16 PM
cgfen's Avatar
cgfen
Default time for new tires, sizing question for 997.2
Chairman Meows 2S needs new rubber after 18k miles.
(actually, i'm a bit surprised the rears lasted as long as they have, but inside of both tires are down to the wear bars).
Factory sizes =
235 - 35 X 19
295 - 30 X 19
She has "rubber envy" when she sees my 993 WB with 305s and wants to move up a size.
Have you successfully gone up a size to
245 - 35 X 19
305 - 30 X 19
and not had rubbing issues?
Wheels will remain Stock Carrera Classics, (I think that's what the simple 5 spokes are called), 8" and 11".
Thanks,
Craig
Old Jun 26, 2011 | 10:40 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
There is no real benefit to upsize the fronts. Stay with the 235. For the back end you can easily go to 305s with merely a 19x11 inch wheel. Recall that the 305 is standard on the 19x11.5 inch wheels. It's not much of a stretch to go up to 305.
Old Jun 26, 2011 | 10:55 PM
okbarnett's Avatar
okbarnett
They use 305 on 11 and 11.5
Old Jun 27, 2011 | 07:54 AM
mten's Avatar
mten
I replaced my 295x30x19 with 305x30x19 on 11s, no rubbing, or feel any difference in driveability. I kept the front sizing.
Old Jun 27, 2011 | 12:16 PM
okbarnett's Avatar
okbarnett
235/35 is a good size for 8, 8.5.
245 will be taller
Old Jun 27, 2011 | 02:38 PM
utkinpol's Avatar
utkinpol
go with 235/295 or 245/305 if you got 8.5"/11" rims. if front is only 8" wide then 245 is a bit too wide for it. 235 will be better.
235/305 tires usually do not have correct ratio of diameters - check for tire sizes carefully to maintain proper ratio between front/rear diameters.
Old Jun 27, 2011 | 05:58 PM
cgfen's Avatar
cgfen
Thanks for the feedback.
Craig
Old Jun 27, 2011 | 06:31 PM
ADias's Avatar
ADias
The diff between 295 and 305 is a mere 10mm. I observed that the actual perceived patch size varies that much on the same size from brand to brand...
Old Jun 27, 2011 | 07:47 PM
DHC's Avatar
DHC
What brand are you thinking? Super Sports?
