Brake Rotors turn rust brown after washing my Porsche
#61
#63
#64
I take off my rotors and clean them separately at each wash. That way they won't get rusty and will look perfect for years. I use a tooth brush for cleaning the pad surface, zymol has a new gel for pad cleaning, PAD-1. It's the best because it retains the original Porsche brake pad smell.
I also don't drive my car much because of the risk of rock chips.
#66
I use soft water to wash my cars, the water that came out of the water softener. The water will slip away faster and have lesser spots. Somehow, I’ve never notice rusty rotors except rainy days. Maybe because the soft water and I am in SoCal.
#68
One note if you do your own brake work: The OEM replacement part is partially painted to prevent rusting on non-wearing surfaces. You can buy cheaper rotors on the web, but sometimes these are not painted at all and the hubs will rust and stay ugly. Not such an issue for a track car, but you'll want to spend a couple extra bucks to keep a street car looking nice.
#69
Yes, you can paint them youself. Buy a Caliper paint kit and use that to paint the surfaces that rust.
Google is your friend: http://www.tirerack.com/brakes/acces...|e|6916162453&
I have no affiliation with Tire Rack but I've used the product.
#70
#71
Yes, it's sold to paint calipers. It's high temp paint so it less likely to burn off. He wants to paint the rotor hubs NOT the rotor friction surfaces.
#72
An off topic, but true, rusty rotor story. In 1975 I had a 1966 Jaguar E-Type that I bought in Chicago and drove to the SF Bay Area. The rear main seal was shot and I burned 12 quarts of oil on the trip. When I got home, I had the real main seal replaced (for $900 dollars). I got one block from the shop after the repair and stepped on the brake pedal, a front rotor separated from the hub with a loud SNAP and a strong tug on the steering wheel. The rotor had rusted off of the hub. Proof that Chicago salt stronger than British iron.
#73
I had my front brakes done (pad & discs) and the shop used OEM with partially painted discs. Went to another independent Porsche shop because it was closer (reportedly reputable) but apparently did not use OEM on the rear brakes and now the non-wearing surfaces are rusting. Can I paint them myself? what paint should I use? I am so disappointed. Any suggestions would be appreciated.
wow you resuscitated an old thread....
Just get a cheap spray bottle, use extra virgin olive oil (do not use vegetable oil since it doesnt help lower cholesterol) and spritz the rotors, pads and calipers...LOL haha
j/p - please do not do this!!!
but your high temp caliper paint will work just fine. just dont get it on the contact surface just tape it off and spray the hub.
#74
First time I saw this (the rusty rotors) after a wash I was also shocked! The real surprise was the next morning when I went to drive it and all 4 rotors were "glued" to the calipers & the power & clutch had a tough time to get them to "release"! All normal for Porsche brakes except them high prices PCCBs! Just drive it and all is well, as usual
#75
Finally another solution to this common problem.
Click here to purchase Hyde's Serum Rustopper
STOP the RUST from ruining your wash and details.
Rustopper effortlessly prevents rust from forming on your brake rotors after cleaning wheels and braking systems.
Product features:
- Rustopper was designed to prevent “rust dust” – the initial brake dust on clean wheels that occurs after washing.
- Rustopper’s Acid-free, pH-neutral formula will not attack wheel coatings, lug nuts or braking systems.
- Rustopper is safe on all types of steel and alloy wheels (including chrome and polished wheels), anodized finishes and single stage paints.
Directions for Use:
1. After cleaning wheel and braking system, rinse thoroughly with water and let excess water drip for several seconds.
2. From a close distance, apply liberally to brake rotor surface, spraying in a sweeping motion around the rotor face at least two times.
3. The liquid may fizz as it reacts with the iron rotor. Finally, wipe any excess liquid inside wheel.
Precautions:
Protect against frost or freezing. Do not apply in direct sunlight or to hot wheels.
POSSIBLE EYE AND SKIN IRRITANT. Contains Sodium Nitrite. Avoid contact with eyes and skin. Use in well ventilated areas. In case of eye contact rinse immediately and thoroughly with water. Harmful by inhalation and if swallowed. Repeated or prolonged exposure may cause irritation of eyes and skin. In case of skin contact, wash with soap and water. KEEP OUT OF THE REACH OF CHILDREN.
Product features:
Directions for Use:
Precautions:
Philip Yiu
Detailer's Domain
e-mail: phil@detailersdomain.com
website: www.detailersdomain.com
tel: 201-233-0003
Promo code is rennlist for 10% off anything on the site
Current Sales and Updates
Philip Yiu
Detailer's Domain
tel: 201-233-0003
