My Carrera undergoes a Chapman diet @ $10 a pound.
If you have sport adaptive seats you can save a bunch of weight for the weekend DE. Take both seats out and put in one shell. Be careful, you might get a hernia lifting the sport adaptive seats.
I find myself in the NC mountains tonight heading to Tellico Plains, TN and a night in a "dry" town. Hence the reason I'm carrying all all this beer.
Did I mention the frunk can carry a lot ****?
Tomorrow I'm run the Tail of the Dragon & Cherohala Skyway.
I'm not familiar with the 380.
Like with such a battery you always have to worry about trickle charge, how long did you leave your stereo on, if there would be any issues in cold weather starting, etc...
What's OEM cold cranking amp? If OEM is 800, I really wouldn't use 380. I know it's nice to save a few pounds, but I rather NOT get stuck somewhere with a dead battery than 10 pounds weight save at the wrong side!
PC 925 Specs:
925 cranking amps for 5 seconds
870 cranking amps for 10 seconds
765 cranking amps for 20 seconds
675 cranking amps for 30 seconds
Short circuit current over 2400A
28Ah
52 minute reserve capacity with 25amp load
CCA - 380 (Is this important?)
Cold Cranking Amps: For all the power, durability, and life of our technology, the cca ratings can seem disapointing. That's because the cca ratings are often misunderstood. Odyssey batteries are SLI (starting, lighting and ignition), so if you are looking for a starting or reserve battery the cold cranking numbers can be irrelevant.
The "standard" cca test measures the output of a battery for 30 seconds of crank at 0 degrees with the ending voltage of the battery being 7.2v. Some companies use 15 or 20 seconds and some companies use 32 degrees which can make for better results.
A vehicles starter isn't designed to withstand 30 seconds of cranking so we feel the batteries starting power is more important. The Odyssey part numbers represent the 5 second cranking power of the battery.
The PC680 is rated at 680 amps for 5 seconds, 595 amps for 10 seconds, and 525 amps for 20 seconds. Cranking power is even higher for the first four seconds. Similar sized lead acid batteries are only rated at 180 - 220 amps.
Bruce - Most inspiring frunk pic I've seen in a while in post #17. Thinkin that mutherfrunker of yours could actually carry an entire 'nuther cooler if you got rid of those shoes.
Bruce, would you (or anyone else who has done this mod) mind posting an update with your experience using this 925T + Rennline bracket system for the last few years? Any problems or issues as a DD, starting in cold, running accessories (charging phones, etc), necessity of trickle charger, etc?
My wife's battery is dead so this is a perfect excuse to give her mine and upgrade to this in my car! But as both a DD and track car, it's unclear to me whether this battery is the best option for me. In my experience, you typically have to give something up on the street to get a gain on the track and vice versa...so can this battery really do both street and track duty well??
My Optima battery lasted 5 years. Yes I generally used a trickle charger and the car was indoors. Getting 5 years out of any battery is good I believe. I did notice the car turned over slower in the fifth year. My Carrera is not a DD but I hope the above serves as a data point. No issues with running accessories.
For frame of reference, the 47lb Bosch brick would've set me back $235 at Pepboys so I'm effectively getting a 20lb savings for only $55...or $2.75/pound!!!
Can't wait to install it. I love a good excuse to get out the tools and work on my Pcar!
Oh, by the way, what trickle charger did you use? Was it one of the kind that charge through the cigarette lighter or did you pop the hood and use the alligator clamps each time? The Odyssey tech on the phone recommended at least 7-8A but ideally 10A for max charging potential for these batteries. According to her, the cigarette lighter kind typically don't push that much power so they're suboptimal (and may theoretically void the warranty). Just curious what kind you used and apparently found sufficient. Thanks again for the update!!
Just throwing this out there. What does the 20 lbs do to the already rear weight bias? Is it insignificant to effect that? Older Porsches used ballast in the front to help with the rear weight bias. Does this move the balance in the rear direction with any significance?
