anyone know how to access fog lights on 2011 cayenne?
I can't figure out how to replace my fog light on my base 2011 cayenne. Search shows that a panel could be removed directly below the previous generation cayenne, but I'm not seeing an easy way in. Nothing in the manual. Removed the headlight cluster and found no access lower. I removed five of the torx screws on the wheel well and nothing wanted to budge easily. I removed four of the hex/torx screws on the edge of the lower plastic molding. I was pretty tired and low on patience so I didn't push too hard to remove any parts. Any advice?
crap, thought i was in there.
I belive they are items that on the new Cayennes (we has a 2009 previously) that the dealer has to get to. We changed out our side markers to clear ones and remember because the dealer had to pull the front wheel well cover access to get to them and swap out the clear ones for yellow OEM from the factory as well as change a bulb. Also remember the fogs being the same way. Crazy that they make a car which only the dealer can get to for a light change...
GL and yes check out the Cayenne forum too...as I may be mistaken but don't thinks so.
