Accessing the rear deck lid courtesy bulb?
I meant to report back sooner but now that the temps are scorching here in Texas I was reminded when I popped the engine compartment lid this afternoon to help the cool down, I lock the car and the light goes out in about 10 minutes - 08 997.1 - no need to remove the bulb - same with the luggage compartment light.
for everybody's information, the light is simply removed like any other courtesy light in the car. There is a tab on one side of the light that fits a flat screwdriver, one simply uses this to pry out the light. then you can remove the bulb if you wish to. less than a 2 minute job. However, it seems that most of our brothers are right in saying the light turns off in a few hours. this willnot drain the battery though for sure it shortens the life of the bulb. the bulb is very cheap. so i guess i would not worry about this.
