PCCB Brake help
Old Mar 28, 2011 | 12:14 PM
gellie's Avatar
gellie
Default PCCB Brake help
My PCCB have been squeaking for they last several weeks. I tried hitting the brakes hard at Highway speed as some suggested but that did not work. I brought my car to the Porsche dealer snd they said the brakes were mechnicaly fine. However the performed some kind of" rough or hard Deglazing" on them , whick worked for about 20 miles or so. This squeaking is most noticable on light to moderate braking. Is there anything else i should try? On a bright note they completly fixed to rattle on my Targa roof.
Old Mar 28, 2011 | 01:09 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Sometimes they will squeal a little but I would suggest that it won't stick around for long. My theory is that they like to be hot more. What can be done about it? Very little. Try a variety of techniques.
Old Mar 28, 2011 | 01:35 PM
WaltB's Avatar
WaltB
I have the same issue. Porsche's answer is to get them hot by doing multiply hard braking decelerations. I've done that and it seems to work for a week or so but then comes back. I'll get a chance to really get them hot on my next DE so I will wait until then.
No question it is a little embarrassing to pull up to a red light and have then squeal though.
Old Mar 28, 2011 | 03:16 PM
gellie's Avatar
gellie
Yes can be a little embarrassing. i just got off with my SA. He said its just a matter of geeting them hot enough to deglaze them.. I guess i need to drive her a bit harder...
Old Mar 28, 2011 | 03:33 PM
911SLOW's Avatar
911SLOW
Admin
https://rennlist.com/forums/997-gt2-...formation.html
Check page 2.
Old Mar 28, 2011 | 03:49 PM
gellie's Avatar
gellie
Thanks..Alot of info there.
Old Mar 28, 2011 | 06:54 PM
mdrums's Avatar
mdrums
Yep just wait longer to brake on the interstate off ramp...or better yet, sign up for a DE or Autocross...it will do you and the car good.
Go find a long stretch of country road that is deserted of cars. Get up to 60 or more if your want and brake hard..hard enough to tickle the abs. Slow down to 20-30mph and speed back up and do this over and over about 6-10 times. I bet your PCCB brakes stop squealing.
Old Mar 28, 2011 | 07:33 PM
Macster's Avatar
Macster
SGL Brakes GmbH (which not only makes the PCCBs for Porsche but also similar brakes for Audi, Bentley, Bugatti, and Lamborghini) provides this bedding in new PCCB brake pads procedure:
Phase 1: 15 brake applications of 10 seconds each at a min. deceleration (roughly 20%) from 100 to 50mph at approx. 30 second intervals.
Phase 2: 15 brake applications of 7 seconds each at low deceleration (roughly 30%) from 100 to 50mph at approx. 1 minute intervals.
Phase 3: 15 brake applications of 7 seconds each at medium deceleration (roughly 40%) from 110 to 50mph at approx. 2 minute intervals.
SGL goes on to say the aim of the 1st phase is to create sufficently high contact between the pads and rotors. The 2nd phase and 3rd phase is to fully develop the friction film between the pads and rotors. Phase 3 can be reduced by 2 or 3 brake applications at max. deceleration (ABS control range) from 100 to 110mph down to zero. The time interval between these should be around 3 minutes.
The above I quoted from the 1st of a 3 part article on PCCBs in Total 911. I have I think said it before, and I'll say it again: For anyone that owns a car equipped with PCCBs or is even thinking about a car equipped with PCCBs, these 3 articles are required reading.
Sincerely,
Macster.
Old Mar 28, 2011 | 07:38 PM
mdrums's Avatar
mdrums
Sincerely,
Macster.
Thanks Macster....great info. Problem is people do not drive these cars hard enough to full bed in the brakes and if they do they drive lightly around and glaze them over and will need to redo a bedding in if they squeal again. No big deal and no harm it's just the way things are.
Old Mar 28, 2011 | 11:00 PM
Rocci's Avatar
Rocci
So if you cannot do the recommended bedding-in procedure as soon as you take delivery of the car how should you drive/brake until you can find the right place/time to do this - brake hard on every occasion or break light? And, from the preceding post it sounds like you can redo the bedding procedures over and over again. Am I understanding this correctly?
Old Mar 29, 2011 | 10:18 AM
Zeus993's Avatar
Zeus993
This is a great discussion. I've had a similiar PCCB problem with a "whirring groan" at low and high speeds. It's periodic and I find that it's happening with no brake pressure applied. It can get it to go away with a light touch to the brake, but then it returns later. Irritating more than anything else. Could it be that the calipers are stiff? I'll try the protocal above. Of course it doesn't do it when I take it into the dealership!
Old Mar 29, 2011 | 11:24 AM
gellie's Avatar
gellie
Im also wondering if the cold/dry weather has something to do with this? The dealer insist this wwill go away, after a while with some spirited driving.
Old Jan 6, 2012 | 09:38 PM
box986's Avatar
box986
My PCCB also squeal when I do not applied any brake pressure, the noise goes away as soon as I step on the brake. Is it possible that i have a sticky brake pad that continue to make contact w the rotors which will cause high heat and damage.
Old Jan 6, 2012 | 10:17 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Do you have a 4?
Old Jan 6, 2012 | 11:34 PM
Sharkys's Avatar
Sharkys
51K miles on original PCCBS with 90%/95% pad remaining and virtually no rotor wear. My brakes make noise when I brake lightly coming to a stop at a light or approaching my home or work driveway. The noise however comes and goes, but the noise always comes back when I drive for weeks like a granny. I kind of like the noise actually because it's when I hear it, it gives me a reason to really drive it the way it is supposed to be driven.
