Lug Nut Torque Spec
Lug Nut Torque Spec
Did a search and could not find the answer.
Can someone tell me for a 997.1 C4S what the torque spec is for the lug nuts.
Thanks in advance.
Thanks in advance.
ok thanks again.....lol...just wanted to make sure that by chance there wasn't a different torque spec between the front and rear for some reason....thanks again.
Yes. You're probably aware of this, but tighten the bolts on each wheel in the following pattern, 1-3-5-2-4 or similar (the key is to tighten the next bolt opposite to the one you just did), and make a couple of passes before you get to the final torque.
