Methanol Injection project complete
Just finished the Methanol Injection project with my buddy Ehrin. Should help cool the engine as well as increase the Octane of the tank fuel. We also added an AEM X-WiFi wideband AFR controller. It creates a car WiFi and sends AFR numbers to my I-phone.
The car has a VF-Engineering Supercharger installed with a max boost of 7 PSI.
http://www.youtube.com/watch?v=MoZl0...embedded#at=32
Idle AFR is 14.7
Max boost of 7 PSI shows AFR at 11.5
![](http://i184.photobucket.com/albums/x131/WaltBurkett/_DSC5831.jpg)
![](http://i184.photobucket.com/albums/x131/WaltBurkett/_DSC5829.jpg)
![](http://i184.photobucket.com/albums/x131/WaltBurkett/_DSC5833.jpg)
![](http://i184.photobucket.com/albums/x131/WaltBurkett/_DSC5826.jpg)
Idle AFR is 14.7
![](http://i184.photobucket.com/albums/x131/WaltBurkett/_DSC5818.jpg)
It should cool your air charge by 40 degrees which will prevent knock retard and loss of power. I use it on my supercharged GTO. If you could dyno tune the car with a laptop you could get more timing and more power out of her as well.
