proper upshift technique
Old Feb 20, 2011 | 03:40 AM
alexb76's Avatar
alexb76
In 997, redline for sure!
Now, in my old S4, with a chipped engine, there was an argument to short shift to fall under the sweet spot of Torque, most because the chipped engine had a HUGE Torque spike in mid-range that fell off dramatically over 5500 RPM, and my Dyno also showed Max HP was not at redline, but around 5500... so just to ensure you have the most HP you'd short shift to go BACK to the sweet spot in the next gear. Not the case in our engine.
Old Feb 20, 2011 | 11:03 AM
zanwar's Avatar
zanwar
Upshift when the power and torque starts to fall off, in the mid to high 6's. If there isn't much room left before the braking zone and you can avoid a shift, take it up to the redline.
Old Feb 20, 2011 | 11:29 AM
RollingArt's Avatar
RollingArt
If max acceleration is what your looking for, shift it just like the PDK in Launch Mode.
I think Porsche's engineers know a thing or two about acceleration.
Phil
Old Feb 21, 2011 | 08:32 AM
winkingchef's Avatar
winkingchef
Originally Posted by Fahrer
I have driven a VW TDI in Germany for several years. I often drove at high speeds ( up to 125 mph) and I can tell you that shifting at redline does not produce the fastest acceleration. After about 3500 to 4000 rpm the engine just makes more noise.... not more power. The best power came from 1800 to 3500rpm.
I've highlighted the answer to your question.
Old Feb 21, 2011 | 09:28 AM
Fahrer's Avatar
Fahrer
With a 911 I do believe that maximum acceleration is achieved by shifting close to the redline. But, with many gasoline engines, max acceleration is achieved by shifting well ahead of the redline. As said earlier......it depends.
Old Feb 21, 2011 | 09:41 AM
Marine Blue's Avatar
Marine Blue
My Speed3 needs to be shifted well below redline to maximize acceleration. Power drops off dramatically anywhere near redline, almost as if the Turbo shuts down.
The 928 accelerated best when shifted at redline. At 4500 RPM the car really came alive and the engine continued to pull hard to redline.
So the answer is really dependent on the car.
Old Apr 22, 2011 | 12:44 AM
zanwar's Avatar
zanwar
Scratch my last. Shift at redline if you have the space. Tried this out today and hit a couple of extra mph at the end of the main straight by taking the engine all the way up to redline before shifting.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
