CTEK 3300 Charger
Tried to start my car after an extended vacation and got only a few cranks. I immediately opened the trunk and was relieved that there was still enough juice to perform that task. The manual trunk release is not a job that I take lightly. Charged and started with a charger that I had. Then searched the trickle chargers. Bought the CTEK on ebay. Although my car is driven regularly and the battery is only a year old the heavy snow has put the P car out of action. The CTEK works great. Amazing how a small improvement like this makes me feel so good. Good price and fast shipping from Woody's Custom Shop. No affiliation.
www.woodyscustomshop.com
+1 on CTEK
Those with the CTEK, I just bought one (I believe the 3300) myself since this is around the time of year that there is constant snow up here. I also got the lighter connection. Do you plug it into the console cigarette lighter? I've heard one or two people mention that they use the one in the passenger footwell. Do both places work?
I just bought the Porsche trickle charger( I know it exactly the same as the ctek). Just didn't want to take a chance of voiding my warranty. Works great. This weather sucks. Especially for Porsche owners.
I have a the OEM (CTek-made) charger but rarely use it. If one drives the car at least weekly and drives enough 20-30 miles to replenish charge, there is no need to use the charger. Continuous use of the charger tends to dry out the battery.
Goes back at least to the 01 996 (I had an 01 996 TT) and the battery died under warranty. Had to use the battery charger clipped to the pull out pole in the fuse block to open the trunk, so I could get it started.
Also, try this experiment with yours. Drive your car for a long drive (even 100 plus miles); park and plug in the maintainer. Then report your results. I bet you it will be charging, and not just for a few minutes. The power demands on these cars are such that the alternator does not have enough output to power everything on the car and keep the battery fully charged, in my experience.
I also have a 67 Corvette, that I use a Ctek 3300 maintainer on. That car has no electronics and the power demands are minimal (I don't use the radio, rarely use the heater, never use the AC, hope to never need the wipers, and mostly drive during the day so the lights are not used often). I park that one after driving long drives (I don't do short hops), and the battery is fully charged/the Ctek doesn't come on.
That's why I say, the Porsche power demands are more than the alternator can handle and still keep the battery fully charged with regular driving; adequately charged in daily/regular driving, yes. But not fully. The battery won't last as long in a car driven as you describe vs. one that is driven at least once per week and with the maintainer used.
There is no reason not to use the maintainer (if you can) every time you park. I never had the Porsche Moll battery outlast the warranty on my 5 previous Porsches, but it did outlive the warranty period on my Club Coupe, and I attribute that to using the battery maintainer.
If you have one and don't use it, and are leaving your Porsche parked for days (even if less than a week between drives), not sure why as it is so simple to plug in the lighter, shut the car door and you're done. The Ctek will not dry out the battery.
Also, try this experiment with yours. Drive your car for a long drive (even 100 plus miles); park and plug in the maintainer. Then report your results. [/QUOTE]
I have done that and the charger reports full charge. Note that you may have to rotate the charger switch mode settings as its indicator is a bit sluggish - with that I mean it may indicate charging, but if one switches mode the charge status does change. My car ('10 S) idling consumption is not that high. Of course, I do not lock the car in the garage.
My battery is now fully charged and there is a healthy green light on the Ctek. I used the battery clips as the cig lighter is currently out of stock. My truck was closed but not latched. When I checked the clips the trunk light did not come on. Is this normal? Interior lights worked fine
