2010 Steering Wheel fit into 997.1?
According to Suncoast this http://www.suncoastparts.com/product...de=997S_manual steering wheel should fit the 997.1? Can this be a plug and play? I know it says it needs dealer activation but i have changed my wheel in my 997 many times and is fine as long as you unplug the battery first. Anybody install this wheel into their 997.1?
Thanks,
John
Thanks,
John
Assuming it fits (which I believe it will) what programming are you talking about if you don't have MF now. Just make sure you have the correct airbag (round or triangle). I've swapped 2 steering wheels in 997.1 - both were MF and the replacements were both non-MF - no programming needed.
If you don't have MF now and want MF on new steering wheel, additionally an extra wiring loom and a control module for the steering wheel is required. These fit near the airbag.
Then programming is required by the dealer.
