Tire Gauges
Poseur
I'm a true novice when it comes to a tire pressure gauge. I used to just use the tire gages that came with every new 911 (Porsche used to really do that!) but wonder what the pros and cons are of each type. How does one calibrate one? Can they be, or do you have to mentally apply a correction factor each time?
I bought the Porsche gauge from suncoast, it works *OK* but it's of fairly poor quality and most likely made in China! It is off around 2-3 PSI from my 997.1 TPMS and I have NO CLUE which one is correct.
I probably get one of the other gauges recommended here, as Porsche has totally disappointed with the supplier on their *branded* gauge...
Poseur
Years ago Porsche supplied a VDO labelled pressure gauge to all new car buyers. They seemed to be alright. But have no idea how one rates next to any other.
Serious tracking might require more accuracy, but I think for most, these are fine. The Accutire shows more resolution easier (digital readout), so I get close with the pump and then dial it in with the Accutire, then check the TPMS. Plenty good enough for street driving.
We sell Accutire, but also the Intercomp gauges. They are far better quality. I bought this one and then gave all my other digital ones away! It's been flawless.
I'm still using my now 8 year-old Accutire digital gauge. I was starting to have doubts about its accuracy after so long, but then I tested it against the TPMS on my new MDX and it read identically.
I feel the same way... how do you know which is more accurate/calibrate?
I find it kind of funny that there have been numerous discussions over the years about the best tire pressures to run for street and track etc., and yet, it appears that everyone accepts that there may be calibration issues with gauges.
Go to Racer's Wholesale and get a longacre. I had the Griots. It's cheaply made and kept breaking. While they replaced it twice I finally threw it away the third time. I liked the design but it was just built like sh*t- cheap plastic, stamped metal. Digital or not is up to you but a simple analog one won't need any batteries.
http://www.suncoastparts.com/product//PNA36110002.html
Longacre gauges are very accurate and hold that accuracy for years. I have a five year old one that's perfect. They're built like tanks- you can practically drive over them (not really but trying to make a point). If it were me I would get the simple analog Longacre and never look back. Unless you're tracking the car and making frequent adjustments (for which I would get- and have- the Longacre combi filler and digital gauge) that's all you'll ever need.
