Increasing ground clearance
I've got a 997.1 with PASM. Some may flame me for even considering this but has anyone raised thier car a bit? Any ideas on how best to accomplish this? I live in NJ and I scrape speed bumps and even certain abberations in the road multiple times every day. I'm not excited about the prospect of replacing a paper thin bumper cover a few years from now. Even 20mm would probably help greatly.
I could probably put a 20mm shim above each of the struts but then I'd have to adjust the camber. Any advice on this? I'd prefer not to replace the the entire suspension. I'm wondering if there is shimming that I can do or something to try it out for a while.
thanks
thanks
There are at least two aftermarket "front end lift" systems on the market. Techart makes one and Cargraphic makes another one (and Sharky sells both). I don't have any direct experience with either -- I decided to just replace my front splitter from time to time and deal with the scrapes. Not trying to win any Concours with my car.
No amount of slowing down can accommodate the 30" axle-to-lip front overhang on a 997 if the entry angle is too steep. It's sort of absurd. I scrape my front lip at least four times a day (coming and going from my driveway, coming and going from my office parking deck). There are some parking lots here in Houston I can't negotiate at any speed. Granted, it's worse with the aerokit front bumper, but I had issues even in my C2S.
Yeah, I'm rolling with just the stock front bumpercover c2s. no aerokit.
Both of those front end lifting kits mntioned above are the kind that you need to electronically activate to raise the front. I'm really looking for something that is always raised because i'm not really sure when I'll need it. I guess it would also help with snow slightly.
maybe just taller springs with the same spring rate?
Still seems strange that a non aero kit stock height car is scrapping that often.
To the OP: Can't you traverse those obstacles obliquely?
Moderator
Porsche makes something called "compensating rings" so the same springs can be used in different markets around the world that require different ride heights. They make a 3mm and 6.5mm I believe. Some cars, have a few of these stacked. I think they cost about $20 a pair or something like that. Maybe try a 3 and 6.5 to basically get about 10mm of height.
http://dcauto.gotdns.com:4000/illust...ndex/799162777
996.343.511.00 is the 3mm version
996.343.511.01 is the 6.5mm version
$5 each, so if you tried 4x 6.5mm that's only $20 plus all the labor (which is big). They are hard rubber, so there might be some compression under weight.
As your Porsche shop - they would probably have better info.
Definately cannot avoid these areas. There are 3 on my daily commute. Have you driven in the NYC/NJ area? the roads are really bad in areas. I'm totally fine out on the highways and in the burbs.
2 are low areas in half of the lane (you can think of them as a soft pothole) when the tire goes in the hole the front scrapes even if you are going dead slow. These are one lane roads and there is no opportunity to go off the roads or into the other lane. taking another road will add 20-30 minutes to my commute. I also scrape going into the garage at work. The garage is an early 1900s factory that was converted into a garage and it has a brick ramp leading up to it.
thanks for the info on the rings. I'll give those a shot. It's not beyond my skills to put them in myself, I'd have to take it in for a camber adjustment/alignment though if it gets out of whack.
this is what you want
about $5K but it will do what you want without wrecking the looks or handling of you car
http://www.vividracing.com/catalog/k...5-p-55224.html
check the video
check the video
Moderator
A lift kit isn't going to solve this. I'm in CT and unfortunately have to drive the roads OP is referencing. 99.9% of posts about ride height are about lowering for "looks", this one needs to raise to simply be able to drive the car on the crater-filled NJ roadways.
By the way, I learned about the compensator rings on a Boxster forum. Sure enough, my 05 Boxster S had compensator rings and what those in the know do is lift the car, snip the hard rubber rings and pull them out, and instant lowering of the suspension. New alignment then allows more camber - I think we got -1 up front vs. a typical of maybe -0.8.
thanks
thanks
So did you ever succeed in increasing the ground clearance? I could do with that right now.
Kay
my car sits fairly low. 997 GTS SPASM. I'm happy with how low it is.. but it very occasionally (I only know one spot in town that I regularly drive by) will have a light scrape on the lip. It doesn't bother me so much considering how light the contact is, and I can drive to minimize down to a hardly discernible brush.
I recently changed the wheels on the car and changed up from OE tire spec. I went from OE spec to GT2 RS tire sizing. My reason for doing that was threefold. Getting wider wheels, OE spec had a slightly stretched look I don't like, and to fill in the wheel gap just a touch. No desire to move up from the SPASM to an aftermarket setup just yet. A fringe benefit of that has been just a few mm difference in absolute ride height. I'd imagine not more than 5mm, if that. But its just enough that I don't scrape on that one spot on my way to the office anymore.
Something to consider.
edit;
just realized the poster above me is necroposting
edit;
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
edit;
just realized the poster above me is necroposting![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
edit;
