GT3 Control Arms Fit 997.2 CS?
I believe 997.1 and 997.2 LCA's are the same. You can cal Ryan at Suncoast to confirm. Note that changing trailing arms is not necessary, you can just put washers there. Tarett include the washers in their kit.
I have RSS Tarmac Series LCA's and they are very nice too.
T.
T.
Yes they sure do... I have them on my car. You need to make sure you get the parts for the Litronics mount for the lights.
Like tcouture said the RSS Tarmac series is nice and the Tarret lower control arms too.
I have Tarret (996) GT3 lower control arms in my 997.2 C2S with the Litronics kit and a 16mm shim on each side. The LCA spacers are not needed due to the size of the shim. Currently have -2.44 degrees camber in the front and -2.39 in the rear. The degree of negative camber in the rear was achieved without any modification to the suspension. The front grip is so vastly improved with the GT3 LCAs that it seems (to me) essential to approximately match the rear and front camber settings.
...Richard
...Richard
