Removing and replacing badges
Old Nov 24, 2010 | 09:29 PM
PJorgen's Avatar
PJorgen
Default Removing and replacing badges
I've got a Racing Green C2S and I was thinking that the Carrera S badge (actually 2 badges as they're separate) on the rear would look better in a matte or semi-gloss black. Sort of a stealth look.
So the plan would be to remove the badges, paint and replace. Assume I could use the standard hair dryer/dental floss technique to remove them.
Questions:
Krylon or equivalent spray paint?
How do I stick them back on?
Best way to ensure that I've put them back in the right location?
Old Nov 24, 2010 | 09:37 PM
RonCT's Avatar
RonCT
Moderator
Sounds pretty complicated, have you considered just going badgeless for that true stealth look?
File Type: jpg
Old Nov 24, 2010 | 10:06 PM
Thundertub's Avatar
Thundertub
Cool
I don't know about re-sticking them, but they come new with an adhesive protection sheet on the back which is peel-and-stick. Perhaps it would be easier to just buy a new set, paint them, and stick those on instead of trying to re-stick the old ones. I've tried to re-stick removed emblems without much success. The adhesive never seems to stick as well the second time around.
Old Nov 24, 2010 | 10:07 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Putting them back on is a lot more complicated then you would think. Take plenty of photos first, and then outline the area inside which the badges fit with something like blue painter's tape.
The factory uses very slick templates that fit entirely over the rear decklid and within the field are cutouts for the badges. You simply take off the protective stuff on the doublestick tape and then place them onto the template.
Once you take these things off the doublestick tape is essentially shot--keep that in mind as you are prying them off with dental floss. It would normally require you to buy a new set (Carrera and S) of badges to get the doublestick to work correctly.
When you paint those things you have to remember that you don't want to affect the doublestick tape as you paint the emblems.
I did it the easy way--I let Zuffenhausen do it!
File Type: jpg
Old Nov 24, 2010 | 10:35 PM
Leader's Avatar
Leader
Bumperplugs.com can fix you up with badging in any color you like.
It's not exactly inexpensive, but it will exceed factory standards.
Wait until you get the new ones from Eric before you remove the originals.
Then, instead of completely cleaning the area (just clean 90% of the old schmutz off), you can easily place the new badging exactly in place, guided by a little residue from the old ones.
Old Nov 24, 2010 | 11:57 PM
mdrobc1213's Avatar
mdrobc1213
I bought another emblem the way I wanted it and had my dealer do the swap out. Pretty easy and I think we have similar cars too! Don't think you'd save much by trying the paint and reuse method rather than buying a new set. Try Eric at bumperplugs or Suncoast.
After and before shots..may help.
Old Nov 25, 2010 | 12:17 AM
niner niner seven's Avatar
niner niner seven
i have never understood messing with Porsche (or founder's) intent
Old Nov 25, 2010 | 12:44 AM
LlBr's Avatar
LlBr
The only way resticking works is by buying NEW badges.
You'd have to be highly skilled model maker with an exacto knife to cut double-stick adhesive foam precisely enough not to look like cr*p.
Also, take your time and make a jig to exactly locate the new pieces before you remove the ones which the factory installed. Something like this to illustrate; certainly it need not be as precise.
File Type: jpg
Old Nov 25, 2010 | 11:51 AM
Taxi?'s Avatar
Taxi?
+1
Old Nov 25, 2010 | 03:28 PM
PJorgen's Avatar
PJorgen
Thanks for all the valuable input and insight. Most important thing I learned is that it probably isn't as simple as I assumed it would be.
I'm seriously considering just debadging for the complete stealth look per Ron's suggestion. In any case, I'll measure carefully and take copious photos in case I want to go back to stock.
Bumperplugs is an option but I'm a serious DIY'er. Good to have them as a backup in case I totally screw it up.
Happy TG to all.
Old Nov 25, 2010 | 05:47 PM
ross74's Avatar
ross74
you can find matte black "911" badges on the internet. they look pretty cool
Old Nov 25, 2010 | 05:58 PM
Eric - Plug Guy's Avatar
Eric - Plug Guy
Basic Sponsor
Email me anytime with questions.
We stock all OEM badges, and do our magic finish work on them as well. Happy to offer up any suggestions.
eric@bumperplugs.com
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring 6sp
2009 997 Turbo Cab 6sp
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old Nov 25, 2010 | 09:55 PM
Michael T's Avatar
Michael T
I changed the black emblem on my wife's Cayenne to a silver one. I placed blue painters tape left, right, above and below to frame where the emblem was. I then did it one more time to the outside and removed the inner ring of tape. This gave me room to remove the old emblem. I removed the emblem with dental floss and ivory soap to loosen the emblem. I used WD40 to remove the adhesive left on the paint. After cleaning the paint, I framed the blue painters tape back towards the inside, that way I was able to place the new emblem (you get one chance) exactly where the old one was.
Old Nov 27, 2010 | 09:11 PM
gpjli2's Avatar
gpjli2
This makes the most sense if you must. Imo badgeless is for 57 Chevies, not 997's.
Old Nov 28, 2010 | 06:19 PM
PJorgen's Avatar
PJorgen
With apologies to Humphrey Bogart and others...
I don't need no stinkin' badges!
