Hmmm. Just to be sure there is not a reset issue. Hold the window button in the up position to close the window. Release the button then hold it in the up position again. This is the way to reset the one-touch feature on the driver's side after removing/replacing the battery........................
Passenger side on my 06 needs to go half-way up first and then it will go the rest of the way on it's own. I believe it's stated that way in the manual. Working as designed. Try that on yours - hold it till it gets half-way up, then let go and see if it doped the rest on it's own
I don't think there's a question from the OP about the intended operation, but rather, can it be changed and how? - and the second post is correct - works great.
+1. My 07 is the same. Passenger window goes up automatically after it is 1/2 up.
On a side note, I have noticed that the passenger window makes a noise like it is moving up when I turn the ignition key in the first position. Does anybody else hear this when turning the ignition key. I don't think the window actually moves as I have been touching it while starting the car and notice not movement just the noise like it is moving. Thanks
