Multifunction steering wheel in 997.2
http://www.suncoastparts.com/product...newproductpage
Let me know if you buy/install -- esp. if you install it on your own...
Cheers,
Marc
I was wondering the same, then saw this item:
Cheers,
Marc
Cheers,
Marc
Cool, thanks for the link! I definitely won't be installing it myself. I'd likely deploy the airbag and knock myself out.
I did read another post that suggests you can keep the airbag from going off by dIsconnecting the battery...
LOL. Ok, then, let me know how you like it and how many hours of labor the dealer charged to install - I really miss this from my BMW (find myself going to adjust the volume a LOT).
Will do. I'll probably order it after Christmas.
So for $2000 in parts, you can install the new style wheel. I'd also want the heated wheel option... which is my primary motivation for an upgrade. So it will likely end up at $2500 in parts (plus fact that I purchased the XPA Sports wheel that will be a takeoff.. not sure how much if any I can recover of that cost.
Labor extra.
I really do like my older style thicker (XPA?) sports wheel - the plastic bit of the spoke doesn't penetrate the wheel circle on these. A cosmetic thing, but one near to my heart.
I need to go to the dealer and feel these wheels to see how the thickness compares to my XPA Sports wheel.
I have a 2010 C2S coupe with PDK. I just spoke with my local P-Dealer service department about installation of the PDK Multifunction Switch Control Kit, as found on Suncoast. I asked him if all 2010 C2Ss with PDK would have the necessary electrical connections in the steering column in order for this MF switch control kit to be functional and he stated that it was entirely possible that my 2010 C2S may NOT have this necessary connector, in which case they would have removed the steering wheel (not necessary according to Suncoast), and the airbag only to find out that the necessary connector is not present. Question: can anyone state categorically that the 2010 C2S with PDK (coupe) will indeed always have the necessary connector for the MF switch control kit to operate properly. And, secondly, does the steering have to be removed in order to install this MF switch control kit?
I did this install myself last fall. I bought the MF faceplate from Suncoast when it was only $199 and now the price sure have jumped significantly. It took me about 1.5 hour to install. The toughest part was to gently remove the old faceplate without scratching the leather. You must disconnect the battery before doing anything to avoid a concussion from the airbag. There was an instruction on www.6speedonline.com but I don't have the link. After you swap the faceplate you still have to bring the car to the dealer for them activate the MF function. My dealer charge me 1 hour of labor for that. If you rarely tinker with your car then this is not a DIY project for you.
John
John
I did this install myself this spring. I bought the MF faceplate from Suncoast when it was only $199 and now the price sure have jumped significantly. It took me about 1 hour to install. The toughest part was to gently remove the old faceplate without scratching the leather. You must disconnect the battery before doing anything to avoid a concussion from the airbag. There was an instruction on www.6speedonline.com but I don't have the link. After you swap the faceplate you still have to bring the car to the dealer for them activate the MF function. My dealer charge me 1 hour of labor for that. If you rarely tinker with your car then this is not a DIY project for you.
John
John
1) The proper connections were inside of your steering wheel assy to connect the MF connector to
2) You did not have to remove your steering wheel to install the MF face plate
Are these correct?
1) All connectors are under the airbag; only 3 plugs and ground connector. 2 for airbag and other for the PDK paddle and MF function.
2) No need to remove the steering wheel. Just double tape the leather and plastic to avoid cuts and dents.
Here is the link http://www.6speedonline.com/forums/9...997-2-a-4.html
John
John
Here are couple photos of the original face plate. The blue, yellow and ground is for the airbag and the large orange connector is for the PDK paddle and MF function.
