clicking from brake pedal
Hi, I am the new P owner. Just bought 2011 C2 3 month ago.
I did not realize the clicking noise from Brake pedal before but it is started to annoying me. It is the noise from brake light switch in the pedal assembly.
I had similar problem with Mercedes, and they lube and it came back again, so they changed little plastic switch which had spring in it.
Well, I went to Porsche dealer last friday and tech told me it is normal.
I did test 911 turbo in the showroom and it also had slight clicking.
But since I drive to NYC everyday, always with stop and go traffic, this clicking is really annoying me. It sound like the brake light switch is too lose and it is moving around. This noise happens when I depress the pedal, and let it go.
It also happens when I depress pedal and press it more to stop. Does anyone know how to fix this or fixed in your cars?
I want to have more knowledge before I go back to dealer.
Thank you in advance.
Are you saying there is no fix? oh~no!...
I also tried with turbo in the showroom and I heard same sound but not as much as mine. Anyway, I will ask tech to reduce the noise at least since I can't accept this kind of noise from 90k~ car.
