Sport Chrono rattle
Need some help from some of the more experienced members.
I have a bad rattle coming from the face of my sport chrono. The bezel around the outside front edge of the clock rattles when I tap it. Yeah I know, stop tapping it.
Unfortunately it rattles when I drive also.
Any suggestions on how to remove, disassemble or stop the rattle. Can't find anything about it when I search.
Thanks in advance.
Dave.
Thanks in advance.
Dave.
You might want to check out this article, Dave.
May have to be a member to see the images.
http://www.renntech.org/forums/index...t=#entry162618
Hmm, after further inspection this evening it appears the entire clock module is loose in the pod. So I guess I'll need to figure out how to pry the pod off the dash.
Sport Chrono Pod removal is quite simple. Hope you can figure out the rattle......
http://www.macarbon.com/install_guid...on%20guide.pdf
Perfect, thanks guys. Hopefully will be able to do this on the weekend and fix it.
Cheers
Cheers
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
