Difficulty shifting into 1st ......
Had a new Pressure Plate & clutch installed on my '05 997S a few weeks back.
Periodically I have difficulty shifting to 1st from a green light for example.....
Is it possible that I need a shift linkage adjustment. It feels like its stuck between 1st & 3rd and can't find 1st.
Thanks for help & info.
Edit/Delete Message
Edit/Delete Message
Poseur
Are you in a cooler area? Keep in mind that if you have a short shifter you will have a balkier shifter than the stock when things are cold.
Edit/Delete Message
Edit/Delete Message
